Help Mounting Gauges in Dash
Z_Enthusiast
If you have 2 1/16" gauges for all 3 then the best solution is to either get two more clock faces/rings, or you can cut out the divider between the faces on the other gauges and slip the 2 1/16" gauges into them.
If they are 2 5/8", then you need to get a little more creative. I ended up drilling holes in the back of the gauge cups to use the studs on my Autometer gauges, along with some holes for the lighting and hoses (mechanical gauges). My gauges actually slide into the front of the cups and I trimmed out the gauge ring a little bit to get them to sit just how I wanted them to.
