Super AFC install - need help
awd92gsx
Hey guys,
Well, I finally got the Super AFC that was owed to me and will be installing it probably next weekend...
However, I don't have a FSM for my '77 280Z and was wondering if somebody could scan the ECU schematics for me.
It looks like the Super AFC won't have any problems connecting to the Z's ECU. The SAFC has settings for the Flap style AFM and is adjustable for different types of TPS systems...so I think it should work just fine...
I'm going to experiment with getting my larger than stock fuel injectors under control without having to mess with the adjustable FPR. The problem with the AFPR is that I can tune it fine for high rpm, or fine for low rpm, but can't seem to get it quite right for both...that's where the SAFC will come in.
If nobody can scan the schematic for me, I need to know at least these wire colors off of the ECU...
Power (that one I can find pretty easily)
Ground (should be black I'm sure)
TPS signal
AFM
RPM (tach signal)
That should be about it...thanks for any help I may receive!!!
