Voltage pulse at fuel level sending unit
 about 1/2 second pulse using analog volt meter. Voltage jumps all over with digital meter. Ground at sending unit is good.
Fuel gage doesn't work.
reading 60 ohm at sending unit. I read on the forum 90 ohm empty 10 ohm full. Ohms do change with various levels of fuel.
I had am MG that had a pulse to the unit to level out fuel sloshing around in the tank. Is the pulse normal for a 240Z. The manual doesn't indicate a pulse.
Any ideas what might cause this if not normal? I hate to pull the gage but do need fuel level.
thanks guys
Dave
