conflicting 02 readings
davek
L28ET with MS3X sequential spark & fuel.
Innovate MTX-L wide band
I have it idling pretty good right now. but wide band reading about 3.5 and TS reading about 4.5
Which could be correct and how do I synchronize them. Tuner Studio user guide wasn't very clear.
When starting a project my choice was wide band(default) or lamnda. I chose default.
and ideas?
Hello Matt
Both are grounded to the same place on my fuse/relay panel I made. From there, master ground goes about 10" to battery post via 12ga wire.
Out of town this week. will get back into it Sat or Sunday. Should I try the programing shown above or you might have other suggestion?
The 9 pin serial cable is a very good data cable and isn't affected by electronic noise. It operates from 3-15 volts whereas most USB cables aren't shielded and operated within a 200 mv range making them very susceptible to electrical noise. I ditched my USB and just use a good quality adapter and my sync problem went away
Finaly got to getting a cable. No excuses.
Followed Megruires vid-James Murray. Everything appeared to program as explained.
Made no difference at all.
MS still reads about 1.0 to 1.1 leaner than my wide band.
Anybody have anymore thoughts? I don't know anyone anywhere to borrow one for a test.
I'm all for that but there isn't much to there to fudge. A little more detail please.
something like this:
I programmed the wide band to 0v = 8.5,   5v = 20
so
calibrate ECU like this
0v = 8.5
5v = 21
seems you could play for hours finding the right offset. for 0 & 5 volts.  It seems you could find a match at say 13AFR but at 11 or 15 they would be off. 2 different curves with only one common point on the curve.
Am I missing something? Do you know a simple way?
cheers Matt
