Cam specs
Guest Locutus
Guest Locutus
is there any way to figure out the cam specs of a cam that is already in a engine with out pulling it, or for that matter on a cam that is not in an engine as well.
Locutus
A dial indicator and degree wheel is the only way on a installed cam. On one out of the block, and at least with Comp Cams, they always have stamped my grind # on the front end of the camshaft. A catalog with lobe profiles, or a call to their tech line will fill in the blanks.
JS
