Ryan Merrill Posted November 4, 2015 Author Share Posted November 4, 2015 (edited) On 10/18/2015 at 7:56 PM, TimZ said: Okay, I have to ask - what boost are you planning to run with this? I'm assuming that the Chinese GT35Rs claim to have the same compressor maps - if so, then they won't be particularly happy at low boost (<1.5PR). Are you planning to intercool it? If you plan to run where the turbos be happier (~2.0 - 2.5PR), you'll probably want to. If you do then it seems like you are going to be somewhere around 800hp (or higher). Do you have a trans that can survive? That's going to require a lot of fuel - what are you planning to do for a fuel system? Trans will be a 4L80e, probably with paddle shifters. Boost will be in the 15-18psi range with meth. 15 PSI should be in the 600 whp range. I am switching to a single turbo for costs. Found a Turbonetics T-76 BB turbo local. Will see if he takes my offer. Edited November 4, 2015 by Ryan Merrill Quote Link to comment Share on other sites More sharing options...
Ryan Merrill Posted November 4, 2015 Author Share Posted November 4, 2015 Back at again today. Worked on the crossover pipe, and started figuring out where I want to put the LS Camaro gas tank. Quote Link to comment Share on other sites More sharing options...
nathaninwa Posted November 4, 2015 Share Posted November 4, 2015 (edited) You might not like a paddle shifter. My 80e has a toggle manual mode with a pro ratchet shifter and the delay from the command to the shift is oddly long. I ended up setting up an rpm shift point. Setting the trans shift point at 6600 nets me almost a 7000rpm shift point Have you mocked up the assecories? Would not want to route a hot pipe in a bad spot Gas tank looks good there, nice fit Edited November 4, 2015 by nathaninwa Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted November 4, 2015 Share Posted November 4, 2015 Nows the time to install a mount for a parachute or trailer hitch (Drag Week). Quote Link to comment Share on other sites More sharing options...
Ryan Merrill Posted November 4, 2015 Author Share Posted November 4, 2015 On 11/4/2015 at 6:09 AM, nathaninwa said: You might not like a paddle shifter. My 80e has a toggle manual mode with a pro ratchet shifter and the delay from the command to the shift is oddly long. I ended up setting up an rpm shift point. Setting the trans shift point at 6600 nets me almost a 7000rpm shift point Have you mocked up the assecories? Would not want to route a hot pipe in a bad spot Gas tank looks good there, nice fit Good to know about the delay. Does this apply to all the command boxes or just the paddle versions. Suggestion for the shifter would be appreciated. I wont be running any accessories other than water pump and alternator. Car has manual brakes and steering. Alternator is a low mount and I left extra room to keep the heat away. Quote Link to comment Share on other sites More sharing options...
Ryan Merrill Posted November 4, 2015 Author Share Posted November 4, 2015 On 11/4/2015 at 1:23 PM, RebekahsZ said: Nows the time to install a mount for a parachute or trailer hitch (Drag Week). That's probably a year off. Damn budgets. Do the kids need really an education lol? Quote Link to comment Share on other sites More sharing options...
MrPhotographer06 Posted November 5, 2015 Share Posted November 5, 2015 I also am doing the paddle shifters from TCI on a 4l60e. Going to take it easy until a 80e is in budget. But, you guys should look into built transmissions lolWhen built and tuned.. Ive had shifts quicker than i can move my hand back from the shifter.. Quote Link to comment Share on other sites More sharing options...
nathaninwa Posted November 5, 2015 Share Posted November 5, 2015 (edited) I bet there is huge mechanical differences between the 60e and 80e. Mines rebuilt using Jakes stage 2 with all the internal th400 mods along with Jakes modified valve body with tranny brake. From what I understand of the 400, the clusters for each gear have to spin opposite each other. It's weird tho, no lag between gears, just delayed. This is using the controller in manual mode and auto mode. However, while doing a burnout in the box the shifts are instant. Might be an rpm thing. I said something to jake and he mentioned that it is normal for that Edit. Maybe it is the transbrake valve body and fixed th400 line pressure setup. Shifts are firm and hard, just delayed from the command signal Edited November 5, 2015 by nathaninwa Quote Link to comment Share on other sites More sharing options...
