rickyellow zee Posted December 3, 2015 Share Posted December 3, 2015 Does anyone know the thread pitch for the rear hub. Its the one that the lock nut holds the spindle together with? Its the 27mm one. I messed up the last 2 threads while doing a rear bearing replacement. Thanks Quote Link to comment Share on other sites More sharing options...
z240 Posted December 4, 2015 Share Posted December 4, 2015 (edited) 20 x 1.5. Pretty sure.. The big set of metric tap and dies from Princess Auto has the ones you need. Whole set might be less than buying a single die from a tool supplier.... Yup, just went out to check. 20 x 1.5. If you end up needed a stub axle, let me know. 240 or 280? Edited December 4, 2015 by z240 Quote Link to comment Share on other sites More sharing options...
