Randy 80ZX 10 Posted December 4, 2015 Share Posted December 4, 2015 Will it work, or what upgrade or modification will I need to do to make it work ? Thank you Randy Quote Link to post Share on other sites
dexter72 12 Posted December 5, 2015 Share Posted December 5, 2015 If your sticking with the Datsun/Nissan, you need a mid 90's on up tps sensor.. Those are the potentiometer type of sensors.. Your zx sensor is basically an on off switch. You can make the later style sensor, which most are smaller, attach to the earlier style sensor mounting plate. Just use the early sensor mounting plate. drill the center hole a little bit larger.. grind down the step on center of the plate.. Drill 2 holes in the bracket to attach the later sensor to the earlier bracket you modified.. Quote Link to post Share on other sites
Randy 80ZX 10 Posted December 5, 2015 Author Share Posted December 5, 2015 Thanks Dexter72 ....I started shoping for a Maxima or Altima TPS and discovered many different sizes and different configurations for connectors,priced anywhere from $25 -$95. Just knowing mine won"t work helps with the research to install a SDS system before I actually begin. THX Randy. Quote Link to post Share on other sites
dexter72 12 Posted December 6, 2015 Share Posted December 6, 2015 Your welcome. Quote Link to post Share on other sites
Randy 80ZX 10 Posted December 25, 2015 Author Share Posted December 25, 2015 Is there a specific year & model TPS that I can use? Quote Link to post Share on other sites
