slownrusty Posted March 5, 2016 Share Posted March 5, 2016 Guys - On my daily driven 1988 Mazda 323 GT (245,000 miles), I recently replaced the rear wheel bearings - both sides. It went smoothly and one side is perfect while the right is certainly more audible at low speeds and when loaded like taking a corner quickly. I decided to dismantle everything tonight and I discovered that the spindle had "burn" marks on the surface and also on the bearing as well. The spindle is fortunately not damaged and I am positive I can take some sand paper to remove the burn / friction marks. I would appreciate any thoughts and advice as to why this happened and hoping its a bearing tolerance issue? I ordered a new set of bearings tonight. Thanks!! Pictures: Quote Link to comment Share on other sites More sharing options...
NCchris Posted March 5, 2016 Share Posted March 5, 2016 Is the bearing race a somewhat "loose" fit as opposed to a "press" fit in this area? If so see: https://en.wikipedia.org/wiki/Fretting Sorry, link fairy not working today. chris Quote Link to comment Share on other sites More sharing options...
