Ignition wires
rags
For those using distributorless ignition, What wires did you use? Did you have to make your own or is there an application that has the right length? Oh yeah, I mounted the coils just above where the voltage regulator used to be. It's a 240. Thanks.
Joe
I used Magnecor wires. You can get them individually in various lengths, so it's not too bad to come up with something that fits.
These are the best wires that I have found. Don't get caught up in trying to get the lowest impedance wires that you can find - the TEC is _very_ sensitive to ignition interference, and you need all the suppression you can get. I wouldn't even mess with anything else.
