MSD 6AL tach hookup?
I've got a pertronix ignitor in place of the points. Hooked up the MSD, no problem, but of course the tach didn't work. Experimented by connecting the former coil + wire to coil+ with the MSD. Tach then worked, but the motor wouldn't run (shorted out the MSD, I guess?) Uplugged that wire and the car ran fine again.
Then I tried the Chrysler ballast resistor, to no avail. No tach still.
Ideers?
Dan, for the money of buying a tach adapter, I'd add a bit more and just put an aftermarket 5" tach in the thing. Easy to do and not a ton of money. Alot more accurate I'd imagine, also. Any idea how accurate the OE tach will be after the adpater is installed?
