240z shoulder belts
All shoulder belt ends with the pins and the matching slots in the lap belt male end are the same in all years of the 240. 72-73 have the retractable lap belt reels and the pockets to house them behind the seats, otherwise the same.
I stongly recommend upgrading to new modern belt systems in any case unless you are bent on original appearance, which I get, then at least get the webbing replaced.
I have a set of belts from 17813 (12/70) handy, and maybe a couple of others if you want some better pictures. I tended to toss old belts lest I be tempted to use or resell them. I'm old enough to know better now. About some things at least...
Edited by z240
z240,
Thank you for your input sir.
I will be getting both aftermarket and original belts. I want to respect the original design and at least have the OEM ones handy, but my intention is to keep the modern ones in. Just want to be sure I'm investing in the right parts.
