Grommet for SDS EFI Harness
Nigel
So, my plan was to mount the SDS ECU on the driver's side kick pannel (to the left of the clutch peddle). I have a 240, so that would involve drilling a rather large hole (1 1/2" max) through the firewall in order to fit the wiring harness connectors through. The question is, how do I seal up the hole? I've looked through a couple of electronics catalogues, but I don't see any grommets big enough, and none that will actually seal around the wires like the grommet for the factory wiring harness. I might be able to get a 280Z FI harness grommet, but in case I can't, I'd like some suggestions...
Thanks all!
Nigel
I used a 1" grommet, but I cut the hole 1 1/2" x 3/4". The connectors went thru the grommet first, then I shoved the grommet into the hole.
