Sign in to follow this
rayaapp2
Project: Orange Crusher
ASE_MAT's old car.
I purchased this car in mid 2012 from Mr Banks. Having been around this car since 2002 I had grown attached to it despite its known flaws(mainly rust).
In ASE_MAT's Driveway for the last time after sitting on the side for over a year.
But its me so Im gonna drive this thing home right?.... YEP!
So its, clean and set SU carbs back up, replace fuel lines, check coolant system, check lights, bleed brakes, bleed clutch, and break drums free from sitting!
Well, I got it home safe and sound, and kept going. It got a good cleaning to remove the oxidation.
3 shades of Orange shining through.
And then one cold rainy Dec day came around and I got caught out driving in it.
This guy had hydroplaned across from the far left lane to hit me and spin me 180, I got it stabilized in reverse, using the clutch in 5th with braking to attempt to stop... I was traveling 50mph in the slow lane, visibility dropped significantly, I saw him about 6' before he slid into me through the wheel spray. The rain let up just a few min later for me to take these photos as the ambulance arrived to check the other guy and his 4year old in the back.
I got hit off to the left in the above picture, half way between the edge and the guy in the black rain coat... where the large water basin is.
It was time to recover the car the next day.
12552985_1096982676987773_2597031529924312507216_1096982666987774_16205809740219
944659_1096982673654440_8463740864540707
I rented a trailer and strapped it down as best as I could.
12540968_1096980993654608_3091152162451112439493_1096979400321434_77013872514579
After Getting it home, I installed a new clip on it.
12604699_1096976580321716_89790478683341
12496457_1096973796988661_6929336476382512496087_1096973793655328_19104554890650
But After reviewing the costs of now finishing the clip up by painting, then replacing the dog panels, replacing the hatch, replacing the floor pans, and hatch sill, it was time to call it. It was time for a new chassis with my budget, and to pass the torch on to someone else that wanted this one.
I sold the shell welded up with no suspension, no interior, no drive train, and not much else for $400. The guy already had a beat up wrecked 240z, so I was fairly confident that it would be used as a builder. It was a mixed decision for me, but I am determined to transfer all the components to a nice shell and rebuild the Orange Crusher.
12605406_1096975393655168_57165951768409
12514047_1096975390321835_2615704339428412573829_1096975383655169_88852693392992
Clean this thing up a bit
12605546_1096973786988662_71871454620342
After some digging I came up with this Shell for $1800
Its a complete 73, with a nice interior, no sun roof, and straight body...
12573951_1096972496988791_41117632972760
12400570_1096972486988792_3128199917587812523914_1096971073655600_62715654281331
There are some small signs of rust... but I was planning on painting it orange, man I was in for much more than I thought.
12573892_1096971063655601_58215318073534
Cleaning all the crap off the bottom is always fun
12573227_1096971070322267_8557443022808512523028_1096971066988934_7249164568861912573129_1096971060322268_85487478301694
Fitting The Crushers panels
12548919_1096969716989069_66171960743048
 And one Fairlady Grill
12509119_1096969713655736_62377852037519
I discovered a Datsun 8track and EQ
12417687_1096969703655737_52381150363390
I also pulled the trigger on some TWM TBS
12522943_1096967933655914_52883928797955
And an LD28 pan
12552892_1096972490322125_66952009026440
12417833_1096963656989675_26952942470487
You can probably see Dereks crank trigger stuff and his block off plate for the distributor. And the TWM TB's installed. Im going to need a nice cold air box with horns I think. My header could use some help, I dont want to change it, but its not replaceable unless I have Troy Ermish copy it and spend several grand... which would make me question if I want to keep it at all or if there was something better... So I dont know where I am going with that. I do have ARP head studs, fresh bearings, and the aluminum bar stock drilled oil bar. There are some old Schneider valve springs in this engine as well. Kameari head gasket. But it is questionable if this will be it. Im seriously tempted to open it back up, put some flat top pistons inside this, get a nice cam, port the head, and max grind the crankshaft. We shall see where it goes.
And then the car waited its turn for a year....
12540791_1096963666989674_93551071003837
Are you ready? What have I gotten myself into? Out of the frying pan into the fire... sigh
12549028_1096955410323833_38551841943042
12552928_1096954076990633_8728065249370212321222_1096955416990499_4370178997502112523021_1096954073657300_7917798599337812438999_1096954070323967_8335186971479612509664_1096952533657454_6431918133883712573823_1096951196990921_5083152738945812523026_1096951190324255_62690246351468
12573959_1096951193657588_7879618241611512509455_1096951183657589_67569106497138
Oh yeah,
Off to the Watsonville Shop where Eric Crafton will work his hand crafted tig metal skilled magic!
12541046_1096948696991171_6770591829775612541111_1096948703657837_6144504651143112376398_1096948706991170_15121857190787
Safe and Sound.
I sprung for an '05 Subaru WRX STI R180 CLSD rear end.
John Williams Stub axles
A very nice writeup on it here: CLICKY
Subaru Says the Spring Clips are 28033PA070 and Ive ordered them, but havent confirmed fitment yet.
I have absolutely failed at my suspension documentation. The Maxima rear brakes, Toyota 4 piston calipers, Cleaned and painted control arms, and related bolt on suspension components, the differential, the axles with fresh new U joints, and everything else Ive put under this car. I will be going to watsonville(250miles from where I live) and installing the hopefully correct spring clips for Johns stub axle conversion. Ill make sure and actually take pictures.
12493921_1096948710324503_8893812090086112525412_1096948700324504_6711339727148114444760_1268288606523845_63574712891974
Share this post
Link to post
The Crusher Update. Its minor but Im happy to share.
16708593_1418005738218797_40743814042905
16711716_1418006358218735_40283471312557
Shes covered in dust.
I inspected my floors and rails underneath. I might need to replace them. We shall see.
16711577_1418005874885450_80869625384621
16708724_1418005904885447_20224563248021
I might get some Bad Dog Frame Rails and Zedd Findings Floor Pans yet.
16684382_1418005921552112_1987382506142316640631_1418005951552109_57868016777039
16708466_1418006001552104_89057333158052
John William's Stubs in my STI diff
16640735_1418006034885434_30746726399457
16640808_1418006051552099_13041385784902
Isnt this cute... a 8 track... LOL
16684168_1418006081552096_40018292028171
Disaster...
16708458_1418006108218760_26389508165197
But repairs are happening
16729336_1418006134885424_1824644054730016730357_1418006171552087_79853987095519
16602596_1418006198218751_40919389420508
16684172_1418006241552080_8792082799927216729193_1418006288218742_89854856207659
Ive re-fitted my spoiler. Feels good to have that back on.
16508866_1418005694885468_5432844295429816603063_1418005718218799_71518459283041
16730419_1418005728218798_12076146093154
Share this post
Link to post
