BAlford Posted March 30, 2002 Share Posted March 30, 2002 We are finishing up on a 1982 280ZX and can not get current through the starting circut. A large white wire with a black tracer is in the plug on the back of the ing switch. As best I can tell when I turn the key to start current should flow through the back of the switch to the large yellow wire. My car does not have the relay only goes through a switch on the trans. Then to the starter solenoid. It does not work. We have removed the ignition, taken the electrical switch off the back of the ignition switch and used a flat blade screw driver to turn the electrical switch and it works. We have tried this with two seperate ignition switches and both do the same thing. What are we ddoing wrong? See my car waskomtexas@waskomtexas.com Quote Link to comment Share on other sites More sharing options...
BAlford Posted March 30, 2002 Author Share Posted March 30, 2002 We found out how to fix the problem. We took the electric portion off the lock part. We took a pare af plires and bent the square part that turns the electrical part of the switch slightly and it worked fine. Quote Link to comment Share on other sites More sharing options...
