LiquidCMR Posted May 31, 2017 Share Posted May 31, 2017 Hello All, I've had MS-2 3.57 running fine with some ugly wiring and few fuses for a couple of years on my '82 Turbo Z motor. I'm now in the middle of wiring in the MS Relay Board (20 connections) which has built in relays and fuses. The question I have is regarding my EBC setup. I'm using FIDLE (pin 30) which grounds the solenoid fine. Where do I run this EBC wire to the Relay Board? I think/assume it would be Pin/Connection #6 but was hoping one of you experts could confirm. What drives me crazy is that the 37 PIN to 20 terminal screw Wire Diagram does not have a solid line connecting 30 to 6 like it does for other connections (see attached) Another question: Can I run 12v power to the EBC via the Relay Board, or should I just keep that coming from a separate relay (not part of the board) like I do now? Thanks! - Liquid Quote Link to comment Share on other sites More sharing options...
LiquidCMR Posted May 31, 2017 Author Share Posted May 31, 2017 Please see wire diagram I'm using here. mspower_ShemV1.2 (3).pdf Quote Link to comment Share on other sites More sharing options...
