timing in relation to gas mileage.....
tec280zx
Guest greimann
Actually modifying a motor for more power usually means making it more efficient. Low restriction exhaust, and intake are two good example of modifications that will increase gas mileage provided you stay out of the throttle, (but that is usually not the point of engine modifications). Advancing timing is another free power and mileage trick, but it I believe it increses NOX emissions, so there is never a free lunch.
The more vacuum the engine makes, the more efficient, and generally power its making. Timing will greatly affect your vacuum, which on an FI engine you can generally look at your MAP pressure to figure this stuff out.
So, a vacuum gauge is proven yet again to be a great all around tuning and troubleshootin tool smile.gif
