do 6cyl conversion kits exist?
There are at least a few different v8 conversion kits available, but are there any 6cyl kits out there, with at least modified motor mounts? Who sells em, for what motors?
I'm not aware of any kits for the v-6. I blocked up my V6 on 2x6s in the desired position, and designed my own. Motor mounts are pretty easy to fabricate and can be done at a welding shop for very little. I think Scottie-GNZ's mounting pads were welded to the frame rails under the 6's stock motor mount location or you can use the stock Datsun mount locations and Datsun motor mounts that bolt into the front of the engine, similar to the old 50s chevy, I think. If you or anyone wants some basic drawings of mine I can send them. (4.3 chev) Once you get the engine where you want it, the rest of the swap is like any other.
JS
[This message has been edited by John Scott (edited April 27, 2000).]
