240z ls1 4L60, engine installation angle
I droped the ls engine in the bay.
Side to side angle was corrected by adding spacers between the block and the engine mount plate. I brought it as close as 1 degree from the chasing level. Good enough for me, I can probably add more thickness and bring it up to 0 degree or keep it at 1 degree. This isn’t my concern
my concern is the backward tilt of the engine and transmission , its at 5 degree.
How far back you guys have? Give me some numbers.
Should I be concerned with the differential angles? Is the angle good enough?
I've read that 3 to 5 degrees of backward tilt is ok for ls engines.
