Timecode Posted July 18, 2018 Share Posted July 18, 2018 Just wanted to share a fix to an issue I had. Car would get terribly lean when boost was ramping up, in my case 3800-4000 rpm. AFR's went to 19 for that moment, not good at 20+ psi!! I'm using the stock rail and had an Aeromotive FPR mounted to the passenger side front fender of the engine compartment, with 2.5 feet of vacuum tube to it. Took me a while to find the solution and it was in part due to a post I read, can't recall who it was, who had the same issue but never fixed it technically. He happened to replace his stock rail with a Perrin and it fixed his issue. All this got me thinking why Nissan put the FPR on the rail in the first place. I thought I needed a fuel damper but Nissan never used one originally, so....I moved the Aeromotive FPR back to the oem FPR location, and have a 8" vacuum line now. Now that it's there, acting as a damper as well (like Nissan intended), you can guess what happened, cars runs great now. Thought I'd share since I see so many people mounting it in the same place I did. Quote Link to comment Share on other sites More sharing options...
Nigel Posted December 31, 2018 Share Posted December 31, 2018 From 2005 https://forums.hybridz.org/topic/40439-effect-of-fpr-mounting-location-on-afrs-long/ Unfortunately, the links to all the pictures are now dead, and I"m not sure if I even have the originals anymore. Nigel Quote Link to comment Share on other sites More sharing options...
