Wako 75R & Wako 79 Special
Nismospek
It appears that the Wako 75S has been discontinued  and has been replaced with two cams, the 75R and 79 Special.
I was able to find a little bit of info here on the 75R which seems to be a little less aggressive than the 75S. Still waiting to hear back on the
specs for the 79 Special. I was able to find some info on the 75R from this website http://www.geocities.jp/kuni_s30z/lgata9.html
Wako 75S
Cam Lift 9.7 mm
Valve lift 14.4 mm ~ 14.6 mm
Central Angle: IN 101 degrees / OUT 103 degrees
Wako 75R
Angle 75 degrees
life 9.2 mm
Valve lift 13.5 mm (lever ratio: 1.47 calculated)
Center Angle (not publicized)
