1983 280ZX engine size compatibility
Hello, Have looked around a bit and can't seem to find the answer. Friend of mine has a '83 280ZX and he's considering replacing the engine without replacing the transmission. The engine is stock right now. Would like to know what engines will bolt right in to everything. Appreciate any help.
Guest Aaron
Welcome. Not much will bolt up to that transmission. Easiest swap would be a turbo L28 from a similar ZXT. The VG30 from a 300ZX(T) might bolt up but I don't know for shure. Outside of that, you are going to need to replace the trans.
