Two - Garrett GT2876R Ball Bearing Turbos - will separate
TimO
This is part of an estate sale.
Two - Garrett GT2876R Ball Bearing Turbos. Will separate.  Originally on a twin turbo RB26.  $400 each plus shipping. New $1029 each. Very good shape. No shaft play.
GT25/40R 280-480hp capability. T25 Flanged Internally Wastegated with built in swing valve.
- Dual Stainless Steel Ball Bearings
  • Oil & Water lube/cooled
CHRA Specs
-Dual Ball Bearing
-Oil and water-cooled bearing housing
-M14x1.5 water ports
Compressor Specs
-0.70 A/R compressor housing 4" inlet 2.5" outlet
-48-trim compressor wheel 2.08/2.99 52.8mm inducer
Turbine Specs
-Available in 0.64 A/R and 0.86 A/R turbine housings with T25 inlet internally wastegated
-53.9mm 76-trim GT28 Inconel turbine wheel
Part Number:
705330-2 - Complete turbocharger with 0.86 A/R turbine housing
Dual Ball Bearing GT25/40-R Turbo assembly with specified ar. T25 style inlet flange with 5 bolt style exit. Large 60- 1 style compressor housing with 4.00" inlet and 2.50" outlet. Very Good response turbo for 4 Cyl applications. This turbo has a flow capacity of about 450HP.
IMG_3374.jpg.4ed70efe3b51ef741a9b3f0aa611b0d2.jpgIMG_3375.jpg.503ebb091b9315005f90e9852100f93e.jpgIMG_3385.thumb.jpg.b77ff51c727abb64e6efc88da77419f3.jpgIMG_3531.thumb.jpg.27d0934738f5002bc6883c2f9358ea6d.jpgIMG_3533.thumb.jpg.59d5fba03c9efe25a655cff74fa6e016.jpgIMG_3535.jpg.5275b8bf8119e5fcb28202495086f93c.jpg
Edited by TimO
