biohzrd Posted July 20, 2002 Share Posted July 20, 2002 to go in a little different direction. i always had a thought of trying to put the ford svo v6 in a z. i think they were rated at 225 hp from factory with the potetial for much more. plus i hate to say it but that was a gorgeous motor to look at. Quote Link to comment Share on other sites More sharing options...
zero Posted July 21, 2002 Share Posted July 21, 2002 just a quick question, what cars did the single turbo vg30det come in? i know the na and tt but not single. Quote Link to comment Share on other sites More sharing options...
mtcookson Posted July 29, 2002 Share Posted July 29, 2002 nissan never made a vg30det engine. it was the vg30et engine out of the older 300zx's. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 2, 2002 Share Posted August 2, 2002 Nissan made several VG engines. VG30ET found in the HZ31/Cima/Gloria in RWD form. VG30DET was a single turbo DOHC engine pushing 255Hp with a single T25 turbo.255hp was @ 6000rpm. this engine was found in the Cima/Gloria Y31-Y33 cars... i have gotten prices of $800 for these engines. there were 2 VG30ET's put into the 300zx(z31). the '84-'87 had 200HP @ 5200rpms, short crank snout, 7.8:1 compression, T3 turbo. these had top feed fuel injectors,6.7psi stock boost. the '88-'89 VG30ET had 205hp @ 5200rpms, longer crank snout, 8.3:1 compression, T25 turbo, these had side feed injectors, 4.5psi stock boost, and w type pistons(floating) like the Z32. '84 thru mid '87 the turbo cars had a borg warner T5.they had a 240mm clutch. mid '87 thru 2/'89 had a nissan unit.they had a 250mm clutch. the borg warner can be identified y its 2 piece construction.the later nissan unit is a single piece and much beefier. '88-'89 ECU was much better too. nissan also made VG20ET,VG33E etc... any questions on VG engines ask. BTW all VG engines had a bore and stroke of 87mmx83mm except for the VG33E wich had a 91.5mmx83mm. Quote Link to comment Share on other sites More sharing options...
mtcookson Posted August 6, 2002 Share Posted August 6, 2002 yeah, i did some research and did find that vg30det. it's basically the same thing as the vg30dett but single turboed right? Quote Link to comment Share on other sites More sharing options...
1FASTKINGCAB Posted August 24, 2002 Share Posted August 24, 2002 NIVO88T: Do you know the part# for the later Z trans? You can make a VG33E-T if you use the VG30E-T's crank, oil pump & front cover in the VG33E block (Frontier/Xtera) would probably make prety good power. Quote Link to comment Share on other sites More sharing options...
