BRAD D Posted December 2, 2002 Share Posted December 2, 2002 A little back ground for you guys who do not know my project. I have a 73 240Z and I’m in the middle of installing a RB26DETT with a GTS-T 5 speed. Here is where I am at. The transmission was touching the old mounting brackets in the tunnel, so I drilled out the spot welds and removed the old mounts, now I moved the motor so far back that the passenger side valve cover vent is now touching the hood catch on the fire wall. I will just dent in the hood catch bracket in order to clear the vent. Now with the motor in place I removed the front turbo and bolted my laser cut flanges to the block and stock 204Z rubber motor mounts. Then I bent up a coat hanger to get the angles and distance between the two plates, and then transferred that to 1.5x1.5 x .25 thick angle iron. And then tack welded the plates to the angle iron then removed them. Now I will take the mounts to my friend and get them TIG welded, sand blasted and painted with POR-15. Then reinstall them and start on the trans mission mount. But how to make that now?? I like the look of these ones that attach to the tunnel what do you guys think? The JTR one just bolts through the floor I don’t know if I like that too much? Scotty GNZ uses that type of mount. So i'm sure it holds up fine. Give me your input. Thanks. I can not figure out how to post pic’s but I can send some to you guys if you want, just let me know. Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted December 3, 2002 Share Posted December 3, 2002 First - I'd dump the stock hood mount. Just drill out the spot welds and run hood pins. They can go right through where the hood bumpers are now - easy install Through the floor mounts are fine IMO. They spread the load over a decent sized area and the JTR mount is THICK. I had to have mine sectioned and they actually stalled the chop saw cutting through it That style works darned good... Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted December 3, 2002 Share Posted December 3, 2002 can you please post some pics or send them to my email address. iraqybumm@yahoo.com im plan on doing this swap so all the info would help out. thanks mike sabatino Quote Link to comment Share on other sites More sharing options...
BRAD D Posted December 3, 2002 Author Share Posted December 3, 2002 ON3GO I SENT YOU AN E-MAIL BUT IT BOUNCED BACK? So I'm putting a hole wack load of pic's on yahoo photo but you must use my name and code to sign in. name: RB26DATSUN code: RB26DETT dont mind all the party shots, there is some rb shots in with them as well Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted December 4, 2002 Share Posted December 4, 2002 hey man, thank you for doing that. im now looken at the pics. nice party pics mike Quote Link to comment Share on other sites More sharing options...
kalium99 Posted December 4, 2002 Share Posted December 4, 2002 Dude, you party pretty hard Your car looks well wiked as well, I like the steering wheel. What sort of wheels are they ? Pity that you didnttake pics of the mount when the engine was out of your car. Quote Link to comment Share on other sites More sharing options...
BRAD D Posted December 5, 2002 Author Share Posted December 5, 2002 THANKS THE WHEELS ARE 17 X 7 MOTEGI MR7'S AND I AM TAKING THE MOTOR OUT ONE MORE TIME AFTER ALL THE FITTING WORK IS DONE. THEN I WILL TAKE MORE PICS. IF ANY ONE WANT'S THE AUTOCAD DRAWINGS FOR THE LASER CUT FLANGES I USED TO MAKE THE MOUNTS I CAN E-MAIL THEM TO YOU BLKMGK: I THINK I WILL GO WITH THAT TYPE OF TRANSMISSION MOUNT. Quote Link to comment Share on other sites More sharing options...
