engine question
i was recently looking at jdm engines on a particular site, they wanted 4000 for the front clip of a rb25det, what exactly is included in the front clip?
thanks again guys
p.s. just pulled engine out of my 280zxt
Guest Dan0myte
When a wrecked car comes into a yard, the mechanics there will take a sawzall or cutting torch and slice the car in half, right between the dash and the front seats. They then sell the part with the dash up to the front bumper complete as one whole package. That's a 'front clip'.
Having a front clip makes doing a swap much easier because you have every single relay, wire, transistor, grommet, etc. to do the swap. You have to be searching for parts all the time.
Plus you can physically start the front clip once you hook up a fuel pump and feed it some fuel and most people do this to ensure the engine is healthy before undergoing an extensive and expensive swap.
From your login name sounds like you want to drop a RB25DET into your Z31 - sweet!
Yasin
