Guest Simon Posted February 8, 2003 Share Posted February 8, 2003 Here is the deal, I have a VG30DETT in my Z (not yet) running on propane gas with a blow thru carby setup. I need to figure out some sort of ignition system to use. Does any one know how the Cam mounted Crank angle sensor works? i want to make my own computer to run it.... but i need to know how it works.... I don’t want to put a dissy onto it And info/links would be great Sim Quote Link to comment Share on other sites More sharing options...
Guest Simon Posted February 10, 2003 Share Posted February 10, 2003 Simon (1:37:20PM): any idea how they work Angus (1:37:26PM): yep Angus (1:37:43PM): they have a cylinder about 2-3cm deep with gaps in it Angus (1:37:57PM): which spins around with the cam shaft Angus (1:38:01PM): or crank or whatever Angus (1:38:08PM): and attached to the housing is a haul sensor Angus (1:38:19PM): which signals the coils to fire when it detects a hole Simon (1:38:32PM): cool.... Angus (1:38:38PM): yep.. Angus (1:38:41PM): somethin glike that anyway Angus (1:38:56PM): like in mine there are 3 coils, each one fires for two cylinders Simon (1:39:02PM): so where do i start researching to get a computer to run that Angus (1:39:08PM): so, during each revolution, each cylinder fires twice... Angus (1:39:29PM): i don't know how the crank angle sensor knows which coil to fire... perhaps there are 3 cylindrical things with holes in it Angus (1:39:35PM): hmm not a clue!! Quote Link to comment Share on other sites More sharing options...
Guest Simon Posted February 13, 2003 Share Posted February 13, 2003 surely some one here knows somthing about this! any info is better then none Sim! Quote Link to comment Share on other sites More sharing options...
Guest Simon Posted February 13, 2003 Share Posted February 13, 2003 Here is a link of intrest Programmabl e Ignition Kit Universal High Energy Ignition Kit Quote Link to comment Share on other sites More sharing options...
fl327 Posted February 14, 2003 Share Posted February 14, 2003 Simon, i was wondering if you had some photos of engine fitment, there are a couple front clips here at the shop that are screaming swap over here, not any time soon, but hey i can start the contemplating now cant i? Quote Link to comment Share on other sites More sharing options...
speeder Posted February 14, 2003 Share Posted February 14, 2003 Electromotive HPX Quote Link to comment Share on other sites More sharing options...
Guest Simon Posted February 15, 2003 Share Posted February 15, 2003 Thanks for the link, but i would like to use the haul sensor, (cam mounted crank angle sensor) Sim Quote Link to comment Share on other sites More sharing options...
Guest empracing Posted February 16, 2003 Share Posted February 16, 2003 dude its optical 360 slots for degrees and 6 differant shaped slots for each cylinder the 4 wires are for the light and the reciver try to contact some of the programmable cpu companys for the wireing i know there was a artical in zoom a while ago about a tester for it but i cant find it i have one in the shed i was going to addapt to the L series insteed of the magnet crap it has now but gave up by the way it should have 6 coils my vg30det did Quote Link to comment Share on other sites More sharing options...
Guest zline Posted February 18, 2003 Share Posted February 18, 2003 adapt a 4AGZE DLI ignition if you want a distributorless factory ignition. its easy and you can just set it up with a SDS ECU... itd be a lot easier and cheaper than making your own computer etc., Quote Link to comment Share on other sites More sharing options...
Guest Simon Posted February 20, 2003 Share Posted February 20, 2003 surely some one must know a little more about this than what has been said already! If you know any one who may know can you ask them. because i cant get my car going till i make a computer, i cant afford a retail ignition computer...im a student thanks in advance Quote Link to comment Share on other sites More sharing options...
Guest empracing Posted February 23, 2003 Share Posted February 23, 2003 simon what specificaly do you want to know its a optical trigger it triggers when the light shines thru a slot your computor needs to use it as a base line p.s cpus for cars are bulk cheap try capa or fueltronics in aussie... Quote Link to comment Share on other sites More sharing options...
