thanks for the help fellasbut still lots of advice still ned
thank you fellas that responded to my questions .hey hydra whats up with that 240v8let me know.greimann thanks for your advice as well i was wondering if i went and picked up say a 78 350 from some chevy.does anybody know how much horse they would have about?and also what kind of things could i do to a 78 350 to get more power and still pass smog at the same time?im not into tpi engines i know nothing about them and i love old v8's thanks again for your help fellas and any more advice would be greatley appricated.
Guest greimann
Stock Camaros in '78 put out a wimpy 170 HP with sickly 8.5:1 compression ratio. If you do get an engine from a salvage yard, you would not directly install it into a car without rebuilding it first, so while you have it open, install some flat top pistons, a mild cam, intake manifold and Holley carb and bingo you have an easy 300 HP. All of these modifications can be purchased with C.A.R.B. certification. If you want to go further, get some aftermarket aluminum heads and have 330+ HP. This motor will be a very nice daily driver with enough power to take on any Mustang you come across.
According to Vizard, taking out the (very) restrictive cats and exhaust, not to mention the smog pump, and using the corvette exhaust manifolds brings the '77 Camaro engine up to 225-230bhp. Up the compression a bit, and add a cam and an intake in there and you're easily in the 300s...
check for leaks, run a compression check, check for damage in general, re ring it, re do the head gasket, and stick a blower on top of it, and that 8.5 compression puts you in sick sick blower range, with more hp and torque for the same amount that it would cost you to make it NA and quick. run 10psi baby, run em hard.
oops, didnt read the smog part, ok, do all of the above before i said blower, get it to pass, which should be real easy, go home, and bolt the blower on, youll have around 400lbs of torque under your foot from around idle (thats with a baby charger)
and youll be having zo6s and just about anyone else begging for mercy. thats the cheapest and most power i can see, with all the motorwork youll be in just the same to pump it up na that a super charger would, and not see the same results.
Len, a blower isn't the most cost effective power adder, that would be NOS. The blower itself is pretty expensive, then you have to add an intercooler (if you're gonna run 10psi), not to mention upgrade your carb and fuel system to handle the demands of the motor (big $$) Then you'd also need to beef up your bottom end, with forged rods and pistons etc, and cut a hole in your hood. Bottom line is you can do 300 even 400bhp for pretty cheaply, but once you go over that, things start adding up pricewise
