Cruzzar Posted October 10, 2020 Share Posted October 10, 2020 I have not been able to find the specifications for the distance between the two bolts on the bottom of my 240sx transmission's rear mount. I will be putting this in my 75 280z after doing the machining operations for the front bell. I know that I will have to move the rear trans mount back but what I don't know is will the 75z's rubber/steel isolator bolt up the the Fs5w71c's two bottom trans mount bolts? I don't have access to the car for a few weeks so I can't measure the bolt centerlines on the 4 speed that is in it now. Quote Link to comment Share on other sites More sharing options...
Huy350Z Posted October 11, 2020 Share Posted October 11, 2020 Perhaps this is what you’re looking for: https://technotoytuning.com/nissan/240z/z-type-3-transmission-crossmember-ka-transmission Quote Link to comment Share on other sites More sharing options...
Cruzzar Posted October 11, 2020 Author Share Posted October 11, 2020 I don't know if this is solid mount to the trans or does is use the rubber/steel isolator and if so which isolator-- the 240sx or the 280z's. Quote Link to comment Share on other sites More sharing options...
Huy350Z Posted October 11, 2020 Share Posted October 11, 2020 The original 280Z mount will work. Quote Link to comment Share on other sites More sharing options...
