240Z Turbo Posted July 8, 2001 Share Posted July 8, 2001 Ouch, that is a bit expensive for those units. My buddy was at a boat race in Michigan, so I will have to get you the pricing info tomorrow. You can get those for cheaper than that. As far as the rod, I know Scottie use to run 17psi with the same method of placing more tension on the rod. Quote Link to comment Share on other sites More sharing options...
D83ZXT Posted July 8, 2001 Author Share Posted July 8, 2001 Great! Thanks 240 for the quick response back. I will twist that puppy down. Gotta put that smile back on my face BTW: I went with ACT pressure plate and clutch. (67% more pressure then stock) Thanks again, Donna Quote Link to comment Share on other sites More sharing options...
D83ZXT Posted July 9, 2001 Author Share Posted July 9, 2001 Hi All Is there such a thing as shortening the wastegate rod too short? (Stock) I have no boost controller at this moment. Just the plain old twist the rod that was done on it. As of now, it's boosting @ 8 lbs. So how much more can I twist on stock rod? Thank-You, Donna Hey 240 TT I saw the two Blitz Boost Controllers. $300. and for the Duel $500. Quote Link to comment Share on other sites More sharing options...
