A to Z Posted May 15, 2022 Share Posted May 15, 2022 (edited) Interesting info to put on here for future use by someone searching for it. Wheel spacers on a 240Z. Spacers for the 240Z have a bore hole diameter equal to the raised portion on the rear axle when the drum is removed, which is 2 5/8" in diameter or 66.675 mm. The front hub is 2 7/8" or 73mm in diameter. To put a front spacer on, the bore hole in the center of the spacer has to be milled out to clear the snout and sit flush on the hub surface. So, we are 6.325 mm or 1/4" of difference in bore diameter. This means that the outer diameter of the bore will go outward 1/8" all the way around. This is important, in determining if the hole can be bored out to work with the metal between the spacer hole and the holes for the studs not being too thin to be safely used. Click on link below first drawing to see and think about. Edited May 15, 2022 by A to Z Quote Link to comment Share on other sites More sharing options...
