Tim your right
scottyMIz
The problem is the fuel pump i think.I checked the feul pressure under boost and it goes up at first then drops down from 55 psi to 40 psi.My question is get another better pump?Or bigger injectors?Where you running stock injectors?I can't afford the big injectors you have right now but what ones do you recommend that i can get like off of another car?If you only like the ones you got it will take a little bit before i can get those.Runs better with the AFM adjusted back where i had it just a little rich but still starving for fuel.
My intake manifold has been modified to accept o-ring style injectors (see the recent post in the Fuel Delivery section), so my injectors will not help you. Unfortunately (for you, anyway icon_wink.gif), I never used the stock injectors with my setup.
I believe that James (240ZTurbo) had found some big injectors that at least had the same mounting arrangement at the manifold end of the injectors. I think they were from an RX7 or something. You might find something on that if you do a search.
Scottie, I had a similar problem with fuel pressure hitting peak and then dropping off. It turned out to be my fuel filter and you can easily check this. Bypass the filter and see if the problem persists. Also, make sure your pump is seeing a constant 13+V under boost and somehow now dropping off. I would check the filter 1st before getting a new pump. The Pierburg I bought from Bell was about $200 and is rated at 680hp @ 70psi.
