JLuis Posted February 5, 2024 Share Posted February 5, 2024 (edited) Engine was rebuilt by Robert from RPM Motorsport. Some of his latest engine builds can be found on social media Instagram @robsperformancemotorsport (https://www.instagram.com/robsperformancemotorsport/) F54 Block Block prepped, hot tanked, holes re-tapped, primed and painted with ceramic engine red color paint L28 Crankshaft (polished and chamfered oil journals) 280zx L28 Connecting Rods with 9mm ARP Rod Bolts OEM Nissan Flat Top Pistons 86mm Bore New Crankshaft Main and Connecting Rod bearings New Cloyes Timing Chain Kit New Complete Fel-Pro Gasket Kit New Upgraded Oil Pump (280zx Automatic Turbocharged - polished) New Water Pump (polished) NEW OEM Nissan Water Inlet and Outlet Upper/Lower Thermostat Housing (polished) Includes thermostat Timing Chain Cover (polished) Oil Pan is gloss black (powder coated) Refurbished OEM Motor Mount brackets (cadmium plated) Refurbished OEM exterior hardware such as bolts and brackets (cadmium plated) Refurbished OEM Nissan Harmonic Balancer Damper (professionally rebuilt) NEW OEM Nissan Oil Dipstick (not shown in picture) N42 Cylinder Head Refurbished OEM Nissan stock size Intake/Exhaust valves ISKY 490 Lift Camshaft Springs Kit OEM Nissan Rocker Arms ARP Head Studs Refurbished OEM Nissan Head plate, Fuel Block Off plate, Alternator Bracket and Adjuster, and Water Pump Pulley (cadmium plated) Valve Cover (polished) New NGK BPR6ES-11 (7133) Spark Plug Set New Engine Heater Hose Elbow Water Connector (located on the side of the cylinder head) NEW OEM Nissan Exhaust Studs with Washers and Nuts Estimated compression ratio is roughly about 10:1 Price is $6,500 Local installation may be available for an additional cost. Subject to availability of known resources. Location in Los Angeles, CALIFORNIA Edited February 5, 2024 by JLuis Quote Link to comment Share on other sites More sharing options...
Willflow Posted February 24, 2024 Share Posted February 24, 2024 Really a good price for what's there. A person couldn't replicate it for less. Good luck. Quote Link to comment Share on other sites More sharing options...
JLuis Posted March 1, 2024 Author Share Posted March 1, 2024 Thank you Willflow! Quote Link to comment Share on other sites More sharing options...
Sandy455 Posted September 24, 2024 Share Posted September 24, 2024 Hi. Is this still available? Quote Link to comment Share on other sites More sharing options...
JLuis Posted September 25, 2024 Author Share Posted September 25, 2024 Hi Sandy455, yes. It is still available. I will send you a private message. Quote Link to comment Share on other sites More sharing options...
seventytwo240z Posted February 9 Share Posted February 9 Good day. I know this has been listed for a bit but wanted to check and ask if it's still available? Quote Link to comment Share on other sites More sharing options...
JLuis Posted February 9 Author Share Posted February 9 Good afternoon seventytwo240z, I sent you a private message. Quote Link to comment Share on other sites More sharing options...
