Jason81NA,82RBtt Posted December 31, 2001 Share Posted December 31, 2001 I know that this forum is not for Maxima's, but I respect your opinions very much. Here is the project. I have a 92 SE Maxima, it has the VE30DE motor in it. From what I understand this motor is somewhat releated to the VG30E(T) motor of the 300zx.I had give to me a set of Z31 manifolds and T3 turbo. I know the turbo is good for up to 240-260hp(14psi),Right? The VE30DE already has 190hp and a 10:1 comp ratio.Here the catch. I can't get thicker headgaskets,Boost sensing ignitions(distributorless),or hybrid turbos. So with a decient intercooler what do you guys think will be the max boost this motor will take before detonation? And what hp might I exect from that psi? I know that a lot of other things dictate when detonation accures,but is there a general rule.With those figures would this turbo at ___psi equal a big exhaust restriction. The main thing is it worth the trouble??? Quote Link to comment Share on other sites More sharing options...
warrenp Posted January 2, 2002 Share Posted January 2, 2002 here yah go. got to www.z31.com and www.zcar.com u will get better answers. and u can get better head gaskets! contact NISMO racing or jim wolf tech. u can get any thing from larger cams to t3/t04e turbo's. u can when u order a larger turbo just say it's for a nissan 300zx 1984-1989 pick a year. i think there is a maxima board some where. but i don't think ur trans is good with much boost. i heard of people adding turbo's to non turbo 300zx and didn't put a turbo 300zx transmission in (borg warner t5) so when they added too much boost the trans would not hold up. i doubt ur maxima front wheel drive trans is much better? maybe Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 4, 2002 Share Posted January 4, 2002 If your Maxima is an SE which I think it is, then the only other car(s) that share that engine are other maxima SEs from '92 to '94. It has chain driven cams where the 300ZXs had belts. I doubt the manifolds will work. Quote Link to comment Share on other sites More sharing options...
