A question on increasing rod to stroke
sure . the common bbc has a 6.135" rod, the common aftermarket rod lengths are 6.385", 6.535" ,6.635" 6.70" and 6.80"
look here,
http://www.callies.com/catalog.htm
http://www.oliver-rods.com/
http://www.crower.com/CGI/master.cgi
PG 155
http://www.flatlanderracing.com/index.html
go to connecting rods
now just some info.a 4" stroke 454 would have a 1.53 rod with the stock rods and custom pistons and 6.535" rod gets you a 1.63 ratio.the Ideal ratio for efficient torque production is about 2 to 1 but most production automotive blocks don,t have enough deck height to allow that, the best easily obtained ratio would be with a 3.76" stroke crank from a 427 with a 6.535" rod and custom pistons giveing you a 1.73 to 1 ratio (but that would make the area for the oil rings overlap the piston pin and require additional support rings) . or if your useing a tall deck 10.2" truck block instead of the 9.8" automotive block you can get to a 1.8 ratio with a 6.8" rod and a 3.76" stroke!
btw just as a referance the 327 sbc that some of you think revs so well has a 1.75 ratio and the 302 Z28 engine that everyone knows can be made to scream has a 1.9 to 1 ratio, and most true racing engines like the formula-1 and indy car engines run 2 to 1 or higher ratios
It would cost an arm and a leg, but here goes:
Aftermarket aluminum big block with 11.625 inch deck height bored to 4.440, teamed with a custom 3.470 stroke crank and custom rods in the neighborhood of 8.625 inches gives a R/S ratio of 2.48!
This configuration (4.440 bore x 3.470 stroke) is the famed CanAm 430 used by team McLaren in the first half of the Can-Am series in the late 60's. They used a 10.2 inch deck height, though (I think).
With custom pistons quench matched to Tim Fueling 3 valve heads you could run 14:1 compression on pump gas and get 25 mpg with 500 HP on tap, OR
go with 32V heads from www.araoengineering.com and you could run 13:1 compression on pump gas and have 1,000 HP.
