rk2334 Posted April 15, 2024 Share Posted April 15, 2024 (edited) Hi forum, I have z300 1989 with rb25det,I decided to swap 2jz. Found 2jzGE full built. Edited April 17, 2024 by rk2334 1 Quote Link to comment Share on other sites More sharing options...
rk2334 Posted April 17, 2024 Author Share Posted April 17, 2024 (edited) I have already started and pulled the motor and trans out, romve wirehraness, hammering to make space for CD9 trans clean and paint the bay. Made spacers 22mm height to make clearance between valve cover and bonnet. Edited July 14, 2024 by rk2334 Update pics Quote Link to comment Share on other sites More sharing options...
rk2334 Posted April 17, 2024 Author Share Posted April 17, 2024 (edited) EPS chapter: converting to electrical power steering for Prius.I keept it oem looking,depowered pinion. Edited June 12, 2024 by rk2334 Update pics Quote Link to comment Share on other sites More sharing options...
rk2334 Posted May 3, 2024 Author Share Posted May 3, 2024 (edited) Trans coupling adapter chapter: Bought c009 thrans model cb2 and RB32 double plate clutch (os copy) . Fabricated trans adapter and modify flywheel plate in local shop.Bought arp bolts m10x1.25x6mm. kept engine auto flywheel for starter. Edited June 10, 2024 by rk2334 update pics Quote Link to comment Share on other sites More sharing options...
rk2334 Posted June 10, 2024 Author Share Posted June 10, 2024 (edited) On 4/16/2024 at 10:22 PM, rk2334 said: Engine mount chapter: Edited June 10, 2024 by rk2334 Quote Link to comment Share on other sites More sharing options...
rk2334 Posted June 12, 2024 Author Share Posted June 12, 2024 EBS chapter installing honda 2018 electrical brake, cut studs and add studs female to female adapter . Quote Link to comment Share on other sites More sharing options...
rk2334 Posted July 14, 2024 Author Share Posted July 14, 2024 (edited) Upgrade suspensions bought used lexus is300 suspensions x x Edited July 14, 2024 by rk2334 Update pics Quote Link to comment Share on other sites More sharing options...
rk2334 Posted July 26, 2024 Author Share Posted July 26, 2024 (edited) Engine is in.It fit smoothly with spacers installed. installing headers and intake, but intake is touching brake booster so I turned it 180 degree to make space to fit.Also remove power steering pump impeller put grease inside it and block input and put put holes. Edited July 26, 2024 by rk2334 Update pics 1 Quote Link to comment Share on other sites More sharing options...
Skyloc Posted May 12, 2025 Share Posted May 12, 2025 How did the project end up turning out? I’ve got an 86 that I’d like to do this with… just a dream at the moment. Quote Link to comment Share on other sites More sharing options...
