grumpyvette Posted December 25, 2001 Share Posted December 25, 2001 -------------------------------------------------------------------------------- http://www.tciauto.com/tech_info/trans_dims.htm http://www.nastyz28.com/transid.html http://www.dfwmotorsport.com/Fairlane/9inchrearends.htm http://www.ridgenet.net/~biesiade/Fordrears.html Transmission type: case to external housing: overall length: bellhousing to mount: POWERGLIDE SHORT 15 1/4" 24 1/4" 19 1/2" POWERGLIDE LONG 15 1/4" 27 1/2" 20 1/2" T-200 & T-200C 27 5/8" 27 5/8" 20 1/8" T-250 21 5/8" 27 5/8" 20 3/8" T-350 SHORT 21 5/8" 27 5/8" 20 3/8" T-350 LONG 21 5/8" 30 5/8" 20 3/8" T-400 SHORT 24 3/8" 28 1/4" 26 3/4" T-400 LONG 24 3/8" 34" 28" 200R4 27 3/4" 27 3/4" 26 7/8" 700R4 23 3/8" 27 3/4" 22 3/8" 4L60 23 3/8" 27 3/4" 22 3/8" 4L60-E 23 3/8" 27 3/4" 22 3/8" 4L80-E ??? 31 1/2" 30 3/8" Input/output shaft information Years: Tranny: Number Of Input Shaft Rings: Number Of Input Shaft Splines: Tooth Count: Number Of Output Shaft Splines: 1963-1965 M-20 0 10 24 27 1966-1970 M-20 2 10 21 27 1970-1974 M-20 2 26 21 32 1963-1970 M-21 1 10 26 27 1970-1974 M-21 1 26 26 32 1967-1970 M-22 0 10 26 27 1970-1974 M-22 0 26 26 32 Casting numbers (on case) Years: casting number: 1963 3831704 1964-1965 3851325 1965-1967 3885010 1968-1970 3925660 1970-1974 3925661 Ratios: Years: Type 1st 2nd 3rd 4th Rev 1963-1965 M-20 2.56 1.91 1.48 1.00 3.16 1966-1974 M-20 2.52 1.88 1.46 1.00 3.11 1963-1974 M-21 2.20 1.64 1.28 1.00 2.27 1967-1974 M-22 2.20 1.64 1.28 1.00 2.27 Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 26, 2001 Share Posted December 26, 2001 Thanks for the info very useful. I'll add it to my Tech Folder. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 7, 2002 Share Posted January 7, 2002 bbbowtie: Am in the process of lining up parts for a V8 into a 1979 ZX swap. Can you supply further detail on what's involved in fitting 17" wheels under stock ZX fenderwells? Any tips on wheel offset, coilover use, etc. would be appreciated. My e-mail's on the profile, if you'd rather use it. Quote Link to comment Share on other sites More sharing options...
