Head flow numbers
here
heres the stock flow numbers for the 215cc heads and the 230cc heads are not much differant in flow in stock form
.lift...intake.....exhaust
.200....128..........100
.300....182..........136
.400....224..........162
.500....253..........173
.600....256..........176
.700....265..........178
the AFR flow better out of the box but the DART PRO 1s are the prefered head for extensive porting and can be ported to flow bigger numbers by someone that knows how!heres what a professional porting shop says on the DART PRO- 1 heads: http://www.ondoperformance.com/
here is a average sheet on a set of the 230cc versions, they finish up at
238cc's. for a full stage 3 job the price is $975.00, a stage 2 would be
$650.00. intake matching is $75.00
this may be a bit better
230cc average:
Int Exh
100 ... 84... 100... 55
200 ... 151.. 200... 123
300 ... 208.. 300... 174
400 ... 253.. 400... 209
500 ... 290.. 500... 235
600 ... 316.. 600... 244
700 ... 330.. 700... 254
800 ... 321.. 800... 257
215cc average:
Int Exh
100... 85... 100 ... 55
200... 148.. 200 ... 116
300... 201.. 300 ... 168
400... 246.. 400 ... 200
500... 281.. 500 ... 219
600... 296.. 600 ... 231
700... 303.. 700 ... 238
800... 303.. 800 ... 244
You're great grumpy! Thanks!! I was comparing them to the fast burn heads on the Sallee Chevy site you listed a while ago. The Dart's do flow well when ported, but the fast burn head sounds pretty good, that is if the production head flows at similar numbers. Pretty good price too!
