Guest Anonymous Posted May 7, 2002 Share Posted May 7, 2002 Will the 280ZXT oil pan fit in a 77 280Z? Or will the front suspension get in the way? Thanks Mark Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 7, 2002 Share Posted May 7, 2002 It will fit in a 240Z, because I had one in there. DO you have power steering? i would think that would be the only hold-up. I know my 83 did not like the earlier model oil pan, and I ended up having to replace it after the engine was assembled. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 7, 2002 Share Posted May 7, 2002 WOW!! that was lightning fast!! Thanks No I do not have P/S. What problems did you have w/ the 83 pan. How can I tell if it is a 83 or 81-82. Thanks Mark Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 7, 2002 Share Posted May 7, 2002 I don't know if you can tell by looking or not. I have never really paid any attention to tell you the truth. I dropped a whole turbo engine in my 240, and it fit just fine. I did not have to make any modifications. I think the main difference is the deep part of the pan. I know when I tried to use an early model pan in my ZX, it would not clear the crossmember/streering rack. I had contact there. I would think you would be fine with what you have. Drop it on in just like it was the pan that came on the engine. Good luck. Quote Link to comment Share on other sites More sharing options...
Tony240ZT Posted May 9, 2002 Share Posted May 9, 2002 You should have no problem with clearance. If you want use the pan you have and put a drain hole on the side of it for the oil return. I had to do this when turbo charging my L24, since the L28ET pan does not swap on to the L24 block easily. Quote Link to comment Share on other sites More sharing options...
Guest Tom Scala Posted May 15, 2002 Share Posted May 15, 2002 You will have to use the iol pickup from a turbo motor to use the turbo pan on a n/a block. The baffles in the sump are slightly different between the 2. I found this out the hard way laying on my back under the car wondering why the damn pan wouldn't fit Once I swapped pickups the pan went on no problem. Quote Link to comment Share on other sites More sharing options...
