v trim compressor
Guest hgray14
Check out ebay, and thepartstrader.com
The V trim is a T04B compressor with a 2.180" inducer, and 2.750" major. There is a "Super" V trim that has a 3" major that turbonetics sells, and is better for higher boost.
The inducer is the diamter accross the top part of the compressor wheel, the major is the diameter of the back of the compressor wheel, which must also match the compressor backing plate.
The V-trim is a very good match for a turbo Z engine too. Very responsive, makes good power. Much more than stock.
The inlet of the turbo's compressor housing should be somewhere in the neighborhood of 2.75 to 3 inches too. If it is not, then someone has hogged out a t3 housing, and or pulling your leg. Neither is good.
Good luck.
