MicroSquirt Install
Weber
I'm starting down the path of converting to crankfire ignition using the MicroSquirt. To any of you that are using the MicroSquirt or the MegaSquirt, where did you locate the box? l'm fanatical about clean installations and their notes about the box not being designed to install in the engine bay doesn't leave a lot of options for my '73 240. Any suggestions are greatly appreciated.
  • 3 weeks later...
Hi Weber, this forum is a little slow :-)
I just went through the microsquirt installation on my 76. Here is the thread showing the location for the MS (RH side) and the relay board (LH):
I separated 12V relay board wires from the ECU's to avoid any interference. I also didn't want to put the MS board inside the engine bay.
Regards,
Den
