sixstarlegacy Posted December 16, 2024 Share Posted December 16, 2024 My car is currently running on a stock Nissan ECU with a Wiring Specialties wire loom. It runs and drives, but I want it to be more tuning-friendly, so I got the Elite 2500 HT-151357 PnP during the Black Friday sale. After removing the old ECU, I plugged the Wiring Specialties loom into the adapter and then into the new ECU. I downloaded NSP, which required an update for my 2500. Once everything was set up, I loaded the RB25DET base map for the 2500 into the ECU. Just when I thought it was truly plug-and-play, my car wouldn’t start. It seems the setup is more PnP for Skylines than for Datsun swaps. Does anyone have the correct map to run the 2500 with an RB25DET swap? For now, I’ve switched back to the stock Nissan ECU. Just an FYI, Haltech NSP is replacing ESP. Quote Link to comment Share on other sites More sharing options...
Jcmclaughlin81 Posted August 2 Share Posted August 2 It's not a straight forward plug and play for any car. You have to set your TDC offset angle before it will start up. It's easy to do and there's a write up on how to do it on Haltech's site. https://support.haltech.com/portal/en/kb/articles/calibrating-ignition-timing-7-4-2020 Quote Link to comment Share on other sites More sharing options...
