Guest Tom Scala Posted July 19, 2002 Share Posted July 19, 2002 This is probably on the forums somewhere but I couldn't find it. When reclocking a compressor housing do you do it from the backing plate/bearing housing or just loosen the housing to backing plate bolts & spin it? Isn't there a rubber o-ring in the housing that could be damaged if you rotate it around the backing plate? Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted July 19, 2002 Share Posted July 19, 2002 I am not sure what you call them, but they are the bolts on the backside of the compressiir housing, not the bearing section. Don't loosen them very much and you will be ok. Quote Link to comment Share on other sites More sharing options...
