CableSrv Posted January 7, 2002 Share Posted January 7, 2002 Hey ppl! seeing as i plan on doing a LT-1 swap into the new 240 i'll be getting I wanna fully build out the engine that i get before i put it in. So if anyone knows some good sites and places to get performance parts for the LT1 and T56 trans i'd really appreciate it. Thankz Nick Quote Link to comment Share on other sites More sharing options...
spotfitz Posted January 8, 2002 Share Posted January 8, 2002 Nick, Where in Ft.Worth are you. I live and work just east of there(about 5 minutes away). Want to hook up? Email me Here are some sites that may be of interest to you. It seems you have the same basic plan as I do for your Z. http://www.wopot.com:81/removal/ http://www.rolerdynamics.com/ http://www.cyberauto.com/ http://www.amstreetrod.com/catalog.html http://www.centuryperformance.com/Mallory/index.asp That should keep you busy for awhile. I do have more, just don't have the time to paste them all. Hope it helps Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted January 8, 2002 Share Posted January 8, 2002 Check out www.camaroz28.com Its a huge forum, the threads move so fast, minutes after you post a question, someone has answered it. I have a'94 Z28 6spd, whenever I have a question, I post it there. I think one site that many of those guys get parts from is www.thunderracing.com. They(the forum) helped me figure out a high rpm miss I was having with my Camaro, turned out to be simple tune-up parts Seems to be common on these cars with high mileage, and stock plug wires, plugs and coil. Be aware that that most Forums on the internet are not as nice as HybridZ, these moderators do a superb job of keeping things "on the level". Camaroz28 is not moderated as well as HybridZ, but then again, its a much busier forum. Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted January 8, 2002 Share Posted January 8, 2002 HybridZ moderates itself for the most part. Folks here respect one another for the most part and there's hardly ever any trash talking to moderate... As for the LT1 - watch that damned Optispark and the water pump too. Optisparks aren't cheap and go somewhat often. They're nothing more than a glorified optical distributor and a little bit of dirt or water from a bad waterpump will kill them If you want some adventure they can be dissassembled for an attempt at cleaning... Quote Link to comment Share on other sites More sharing options...
CableSrv Posted January 8, 2002 Author Share Posted January 8, 2002 Spotfitz i'm in the watauga area off rufesnow and 820 and thankz for all the links and yes hybridz is very friendly not as trash talking as some of the boards i've been on tomorrow i'm going look at All Z's in Ft. worth to see if i can find a suitable 1970-73 240z one question tho! did the 240z come with ac originally ? was it an option ? or would i have to swap a 280z ac ? Quote Link to comment Share on other sites More sharing options...
Guest super280z Posted January 8, 2002 Share Posted January 8, 2002 cable, the AC swap is under some pretty serious investigation right now seeing that the JTR mounting method makes AC impossible in the stock location. perhaps a vette bracket? about the motor, if you want a fully built motor i hope you have alot of cash. if not check out camaroz28.com like JamieT suggested.. they have some totally awesome built lt1's up for sale every once in a while. LT1 stuff is just chevy 350 stuff with the exception of the heads and a few other choice items. also might try internet racers supply. the t56's are strong enough to handle pretty much whatever you put them behind. (i said pretty much not anything) happy rodding, Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted January 9, 2002 Share Posted January 9, 2002 look here http://www.automotiverebuilder.com/ar/ar99928.htm http://www.kb-silvolite.com/speclear.htm#CHART http://forums.chevytalk.com/forums/Forum64/HTML/005908.html http://www.carcraft.com/editorial/article.jsp?viewtype=text&id=1004 http://www.kb-silvolite.com/speclear.htm http://www.racingsecrets.com/article_racing-10.html https://web9.tdl.com/jags/MountingKits_Order.html http://www.hpsalvage.com/ http://www.performancess.com/ http://home.tir.com/~steveher/lt4.html http://www.andrew.cmu.edu/~mjr2/cars/supernatural/ http://u2.netgate.net/~jshapiro/heads.htm http://www.thunderracing.com/ Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 11, 2002 Share Posted January 11, 2002 I've had good luck with Internet Racer Supply I got my cam and misc. valvetrain parts from them, and they had them in stock. www.racenet.net/ Mike Quote Link to comment Share on other sites More sharing options...
