Guest Anonymous Posted August 21, 2002 Share Posted August 21, 2002 I want to you a blow off valve to drain water out of the intake charge what will it do to the bov if anything. I want to be able to drain the water when the trottlebody is closed Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 29, 2002 Share Posted August 29, 2002 what the hell you talkin''bout?....do you have a watercooled i.c. or something?....a bypass/blowoff valve will vent the charge (or part of it) out....(the pressure on the throttleplate)...if the charge has water in it i'm sure that would blow out too....i would think it (the bypass valve)would rust if theres water in the charge...but i dont see what keeps the water to air coolers from rusting "everything" anyway...but apparently they dont?.....s Quote Link to comment Share on other sites More sharing options...
TimZ Posted August 29, 2002 Share Posted August 29, 2002 aluminum doesn't rust. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted August 29, 2002 Share Posted August 29, 2002 I think he is talking about the valve itself rusting. I am kind of curious what you are doing that you have water in the intake tract myself. There shouldn't be any in there since we all know water does not compress, which means if you have it in the intake tract and get enough of it into a cylinder, you are going to bend/break all sorts of stuff. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 29, 2002 Share Posted August 29, 2002 Water Injection? Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted August 29, 2002 Share Posted August 29, 2002 I'm thinking maybe so, but without being rude, it is hard to tell sometimes since people don't write very well in their posts. Of course I am making fun when I am using a computer that drops letters all the time. Quote Link to comment Share on other sites More sharing options...
