L28 ITB Engine Build - MS3X Tune Reference Request
joey.youssef
Hello everyone,
I'm getting ready to start my engine for the first time in the next few weeks hopefully. This is an L28 build using MS3X and I would really appreciate any base tunes or configuration files from those with similar setups so I can have a good starting point.
Here's a summary of my engine:
  • L28 using forged pistons, P79 professionally ported head, 10.2:1 compression
  • Isky L6 grind, .540 lift & 270 duration
  • ITBs with TPS and utilizing large balance tube
  • GM MAP and Ford IACV connected to balance tube
  • Crank Trigger and Jeep CAS
  • GM-style coolant temp & oil temp
  • GM-style IAT
  • Electric fans using PWM controller
  • 32 lb/hr bosch injectors
  • GM LS COP
If you've got a similar set-up (ITB, MS3X etc...), I'd appreciate if you can send me your .msq file and a recent datalog if available to get a sense of timing, VE, AFR and idle control settings.
Thanks in advance! I'll be happy to share what I come up with once it's dialed in.
I have also posted this request on FB Church of L Series.
  • Like 1
