Mikelove Posted June 9, 2025 Share Posted June 9, 2025 So I am looking for anyone that has swapped a 350Z VLSD diff into a S30 Chassis. Specifically what axles were used? I seem to be running into posts w broken links and incomplete information on the subject. The diff I am looking at is a VLSD from a 350Z. I know the mounting is different which isn't a big deal. I can work something out including possibly swapping internals to a long nose R200. It comes w stub axles and I will consider a custom axle push comes to shove but wondering if you guys have a hybrid axle solution to make it work? The inner flanges on the diff are 6 bolt and the outer is stock ATM but I can change that if need be. I have looked at weld in adaptors but they all seem to be to adapt the outer flange to a 300Z axle 4 bolt pattern. Which depending on what is avail I can do no issues there. I am just playing w options right now. Anything like a good writeup that i can use or even a solid starting point on which axles may or may not work is appreciated. That includes machining the stub axles on the diff. I was thinking about making 280Z flanges and welding to them to the existing stub axles the using the stock halfshafts. Any ideas are welcome. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted June 9, 2025 Share Posted June 9, 2025 https://forums.hybridz.org/forum/83-drivetrain/ Quote Link to comment Share on other sites More sharing options...
