KKK26 Turbo. Replacement for T3?
Does this turbo work on the stock 280ZXT manifold? I am curious as I see these all over the place very cheap. Under $100.
How well do they work? They are OEM on the 930.
Mike
Mike , the K26 doesnt bolt to the T3 flange (ive got both in the garage... stoopid Audi's confused2.gif ) They are indeed too small for Z use. KKK did make a K27 and K29. The K27 will bolt to the T3 flange and has some massive power potential (blitz uses a K27 variant on thier 35 psi 800hp skyline) The K27's came stock on 911 turbo's I believe. Another problem with the KKK turbo's is they arent set up for an internal wastegate so you have to run an external one. BTW , twin K26's would be madness :D:D
HTH
~Kenny
