240z Restoration in Japan-English Subtitles
Posted (edited)
This 240z restoration in Japan demonstrates bodywork using basic methods and tools.  These videos show restoration methods that most Do It Yourself people out there who do not access to more expensive body working equipment could still do the work.   The restoration using these methods would take more time but have satisfying results.
This Body Man does a lot of Vintage Cars Restoration in Japan.  Race Cars are also done.
Please give your comments so I can find more videos that will help you restore your Vintage 240Z or other car models.
        Toolman
Edited by toolman
test and pic corrections
  • toolman changed the title to 240z Restoration in Japan-English Subtitles
Posted (edited)
Part 2-More 240Z Restoration-
Body Work is mostly done utilizing Oxygen Acetylene Gas Welding.   This method of welding was mainly used to repair automotive body
repair.  I learned this method when I was 15 years old and used it until the 1970s when Mig Wire Welding came in.  The Mig Welding  is
a much productive method as it applied the heat faster and welding with less heat distortion to surrounding metal.  However, I still use this method in certain applications to this day.
Notice- Use a Small Torch Flame and Thin 1/16" Brass Rod.
More Bodywork to come-
Edited by toolman
  • Like 1
Posted (edited)
Part 3-More Bodywork-
In this version, the Mig Welding is also utilized in the restoration process.
Part4-
Edited by toolman
text and pics correction
Posted (edited)
240Z Restoration done in Indonesia-20 min video
Look how many workers  that are working on the restoration at the end.   Just like a Army of Ants.
Edited by toolman
Another S30 Restoration from Japan- no English Subtitles
This short video gives the viewer how restoration can accomplished even with
a badly corroded body.   Note that most of badly corroded areas can be replaced with
aftermarket body panels( even wheelwell edges).  Also, one must realize this work took over months of bodywork by a professional.    Toolman
