madmanadam Posted August 5, 2002 Share Posted August 5, 2002 Not Z related Can anyone help? What would be a good carb for a 1978 440? Right now it has a Thermoquad and looking to up grade. Thanks Adam Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 5, 2002 Share Posted August 5, 2002 If it requires no smog, I'd just get a edelbrock 800 cfm (summit part # EDL-1413) with an electric choke. Its a tad over 300 bones and a good carb. If you need a smog replacement carb this one (summit part # EDL-1905) is a thermoquad replacement at 795 cfm but its expensive at almost 500 bucks. If smog isn't an issue its a no brainer to me Adam. Good luck with it. Regards, Lone Ps: That top carb is essentially a AFB just like chrysler ran on earlier 383/440's anyway. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 6, 2002 Share Posted August 6, 2002 Carter has a newer version of the AFB called the AVS. I've used it on my 74 roadruneer with a 440 and had great luck, plus it used to cost less than the edelbrock. Quote Link to comment Share on other sites More sharing options...
madmanadam Posted August 6, 2002 Author Share Posted August 6, 2002 Thank you, now I need to talk the wife into letting me buy one. Emmisions is not an issue, trip pass for another year then no more emmision. -Adam Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 7, 2002 Share Posted August 7, 2002 Don't be too quick to get rid of the Thermoquad, it can be made to work. Contact the folks at Jet Performance. They rework Quadrajets and Thermoquads into real performers. Quote Link to comment Share on other sites More sharing options...
Guest Pyrogen_007 Posted March 27, 2003 Share Posted March 27, 2003 I agree, the thermoquad is a pretty decent carb runs our 77 Cordoba 400 4v pretty good and some came from the factory with as high as 925cfm rating, although we are running an edelbrock perfromer rpm 750 cfm in the charger with a warmed over 383, but we are in the process of getting a jet kit for it as it runs lean near mid rpm range. Quote Link to comment Share on other sites More sharing options...
